Trickle Charge Batteries
Discussion in 'Power Electronics' started by spike1947, Feb 21, 2016.
  1. spike1947
    spike1947
    54
    Feb 4, 2016
    Hi
    I am wanting to know how I can rig up a simple trickle charge for 4 x AAA Ni-MH Rechargeable Batteries .I need them to run a 5 volt laser for a security set up I am making .
    cheers
    spike
  2. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    How simple? 4 x 1.2v = 4.8v
    Get an adjustable regulator, set 4.8v and stick a resistor on it to trickle charge..
    I've never been too sure about charging cells in series, but i think nimh cells don't mind too much
    spike1947 likes this.
  3. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    LM317 as a current source, used this for years charging 7.2 volt NIMH, with no probs.
    Adam
  4. Colin Mitchell
    Colin Mitchell
    1,416
    314
    Aug 31, 2014
    But you haven't told him what input voltage he needs.
  5. spike1947
    spike1947
    54
    Feb 4, 2016
    Hi cjdelphi
    I don't want to buy a regulator I want to build my own ! .
    cheers
    spike
  6. BobK
    7,682
    1,688
    You can charge them forever at C/20. Any higher and it gets complicated.
  7. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    A couple of transistors and a sense resistor for current regulation? Cheaper and quicker if you buy an lm317/resistor
    Substitute the 10ohm resistor for a value that trickle charges your battery... i selected 10ohm as it sounded reasonable to charge your batteries, just provide the circuit a higher voltage than your battery total voltage
  8. BobK
    7,682
    1,688
    All that is needed is a voltage source significantly higher than the batteries full charge voltage and a resistor. The resistor should be calculated to drop (Vin - Vbatt) at a current of C / 20.
    This will cause a higher charging current when the battery is depleted, which is okay, going down to the C/20 current when the battery is fully charged.
  9. spike1947
    spike1947
    54
    Feb 4, 2016
    Thanks guys , very helpful I now have all the info I need to crack on .
    cheers
    spike
    Arouse1973 likes this.
  10. Alec_t
    Alec_t
    3,055
    833
    Jul 7, 2015
    As explained on the other forum, you need a supply to handle the laser current plus a trickle charge.
