Mozencrath
- Dec 15, 2011
- 13
- Joined
- Dec 15, 2011
- Messages
- 13
So in my Toyota Prius, my 12v system is not powered by an alternator. It is powered via a DC/DC converter whose supply is a 200v battery. It steps it down to anywhere between 12.9v and 14.2v. I do have a 12v battery whose only purpose is to provide the initial startup power of the electronics. The battery is connected to everything that the converter is connected to. The converter has a single voltage sense wire that runs to the + battery terminal. The purpose of this wire is to see what the voltage drop is i.e. gauge the battery level/voltage. This reading that is taken determines whether the converter outputs 13v~ or 14v~...If it senses the voltage drop is great, then it keeps the converter pumping out around 14v, but if the sense line doesn't sense a big voltage difference, it will run at around 13v...
What I need help with is designing a simple circuit that will allow me to fool the sense line. I want the sense line to read a few tenths of a volt higher than the actual voltage at the battery. In fact, the voltage it see's doesn't even have to vary with actual bat voltage. It can be a constant voltage. Anyone know of any simple circuits that can be used to do this?
