S
[email protected]
Hi all,
I'm trying to find a replacement for a triac, Q2006L5 which switches
lights and fan for a range hood. MT1 is shorting to MT2 on the bad
part, especially when compared to a known, good triac (the fan
switches fine, light does not switch off).
My question is can I substitute a 576-Q6006L5 (Mouser part) for the
Q2006l5 (original)? I am an electronics enthusiast, not an expert so
need some advice! I am familiar with some of the specification terms
below but not sure of the relative importance of them all. I have
not had much luck with Google searches or other vendors finding a
small quantity of replacement parts so any suggestions welcomed.
Following are the specifications for the original part and the
proposed substitution part. Thank you in advance for any help with
this request or pointers in the right direction!
Q2006L5 Specifications (original)
V(DRM) Max. (V) : 200
I(T(RMS)) Max. (A) : 6.0
@Temp. (шC) (Test Condition) :
I(TSM) Max. (A) : 60Ò
@ t(w) (s) (Test Condition) :
I(GT) Max. (A) : 50m
V(GT) Max.(V) : 2.5
I(H) Max. (A) Holding Current : 50m
I(D) Max. (A) Leakage Current : 500u
@Temp. (шC) (Test Condition) : 100#
V(T) Max. (V) : 1.6
@I(T) (A) (Test Condition) : 6.0І
dv/dt Min. (V/us) : 50Ò
t(gt) Typ. (s) : 3.0uт
dv/dt(c) Min. (V/us) : 3.0Ò
Minimum Operating Temp (шC) : -40
Maximum Operating Temp (шC) : 110
Package Style : TO-220
Mounting Style : T
576-Q6006L5 (Mouser replacement?)
Specifications RoHS:
Breakover Current IBO Max:80 A
Gate Trigger Current (Igt):50 mA
Gate Trigger Voltage (Vgt):2.5 V
Holding Current (Ih Max):50 mA
Manufacturer:Littelfuse
Maximum Operating Temperature:+ 125 C
Minimum Operating Temperature:- 40 C
Mounting Style:Through Hole
Off-State Leakage Current @ VDRM IDRM:0.05 mA
On-State RMS Current (It RMS):6 A
On-State Voltage:1.6 V
Package / Case:TO-220
Packaging:Bulk
Product:Triacs
Product Categoryower Thyristors
Rated Repetitive Off-State Voltage VDRM:600 V (Min)
Repetitive Peak Forward Blocking Voltage:600 V (Min)
Best Regards,
Bill
V(GT) Max.(V) : 2.5
V(T) Max. (V) : 1.6
Mounting Style : T
Packaging:Bulk
Product:Triacs
Best Regards,
Bill
