Picked up this stuff from an old treadmill, a lot of it was apart so I'm trying to piece everything back together and get this motor working. I need it for a little project. The motor does work, had it working off a 12v car battery, but I've been trying to figure the rest of it out. The transformer, I did an ohms test on the two wires and it was at 2.5ohms. I don't have the on/off or speed switch for it either. I see the circuit board has various labels such as A1, A2, S1, S2, S3, L1, and L2. Not sure where any of these go or where this transformer is suppose to go either. Or would it be just easier to hook up a potentiometer or rheostat??? This is a DC motor running off AC. And does the transformer go between the power and board or board and motor???
By the way pin S2 broke off and I need to solder it back on. I have the motor that came with everything too not shown int he photos. Found this diagram as well, does it relate to my setup??? https://www.minarikdrives.com/descriptions/document/250-0354.pdf But it doesn't show the transformer location either.
