Treadmill motor control board testing
Discussion in 'Troubleshooting and Repair' started by vocal, Apr 17, 2013.
  1. vocal
    vocal
    35
    Apr 17, 2013
    Just replaced 78L12 and machine is working :)
    Thank you very much for your help. It was very useful and I learned something as well.
    Thanks again.
  2. (*steve*)
    25,359
    2,755
    Good job.
    And here you learn something:
    1) if you start from the obvious problem and work backward, the problem will be at the point furthest from where you start!
    2) if you start at the power supply, the fault will likewise be as far as possible away from it :D
    I was starting to think we were being a bit "scatter-gun" in the approach, but it paid off.
    Did you note the output voltage on the 7812 earlier? Did I miss it?
    It's also worth making sure that the 7812 isn't getting hot. There is a possibility that there is a hidden fault or that it's being pushed a little too hard (in which case the 7815 would be having an even harder time...)
    Alternatively, just wait and see if it fails again :)
  3. vocal
    vocal
    35
    Apr 17, 2013
    You did not miss 7812. It was my fault drawing it as transistor. I am sure you would spotted thhis earlier. Machine is used often so it has a good test. If it fails again I will post it. So far I have spare 7812 :)
  4. noxy
    noxy
    Jan 14, 2014
    hi im know here but im looking for the correct name for that board need to buy one for my treadmill
  5. Capsicum
    Capsicum
    4
    Feb 28, 2014
    Is it still working?
    Hi Vocal. Came across your thread by chance and found that your problem and CB are/were identical to mine. Did replacing the transistor work out long term or has it burned out again? Hopefully you'll get this message as I've been trying to fix this problem for over a year now with no luck.
  6. Capsicum
    Capsicum
    4
    Feb 28, 2014
    Hi Steve. I've got the same board as Vocal with the same symptoms:- E1 a few seconds after the start button is pressed because the belt motor doesn't move, if the belt is turned by hand there is no E1 until it stops, belt motor spins if I apply 18V DVC to it, incline motor works fine, no illumination of drive belt motor LED next to large capacitor marked QC1. Problem was sporadic as treadmill would sometimes work for a while and then stop but is now constant. There were 2 plate capacitors next to QC1 shorted out which I've replaced and I also replaced the 78L12 as per the fault with vocal but to no effect. Any thoughts on what might be the problem would be gratefully received but please bear in mind that I'm completely new to electronic work so any advice has to be in terms that an idiot can understand. Thanks in advance.
  7. (*steve*)
    25,359
    2,755
    Start by posting photos of the board as Vocal did. Then we'll start running through the same tests. It may diverge if you get different results.
    Do you own a multimeter?
  8. lasharela
    lasharela
    4
    Mar 29, 2014
  9. (*steve*)
    25,359
    2,755
    There's a lot of parts there. Which is it that you need? What is written on it? (And why do you think that is what you need?)
  10. lasharela
    lasharela
    4
    Mar 29, 2014
    Hi Steve,
    I need this part because it's broken :(
    [​IMG]
  11. lasharela
    lasharela
    4
    Mar 29, 2014
    Can i found whole board?
    [​IMG]
    Aegir likes this.
  12. (*steve*)
    25,359
    2,755
    That's not one part, it's about 30. (edit: actually make that 60 or more)
    I have no idea where you could get a replacement board.
    Why do you think this sub-board has a fault?
  13. lasharela
    lasharela
    4
    Mar 29, 2014
    because, when i'm moving this part sometimes its work.
  14. (*steve*)
    25,359
    2,755
    In that case, the problem may simply be that a solder joint is faulty.
    I would start by looking at all the solder joints on the connector between the two boards. Wiggle the board and see if any move. Do any look unlike the others (dull or crystalline appearance?). Maybe one completely lacks solder!
    Post nice sharp photos of the solder side in the vicinity of the board and we can look too.
    Even if you can't find anything, you can resolder all the joints (typically as simple as melting the solder on each joint in turn) and that will either fix the problem or eliminate it as a possibility.
    There is a smaller chance that the same thing could have happened to any other component on the sub-board, or even on the main board. Another possibility is a crack in either board that has broken a track.
    Most of these problems are pretty easily fixed. Often the hard part is finding them.
  15. Capsicum
    Capsicum
    4
    Feb 28, 2014
    Righto Steve, I'll see if I can get some clear shots of the board and also take a close look at all the solder joints just in case they are the problem. I've got a multimeter but it is very basic. I'll post the pictures ASAP.
  16. vocal
    vocal
    35
    Apr 17, 2013
    Im glad my post was useful to someone. Just to let you know, my machine is working till now :)
  17. davenn
    davenn Moderator
    13,552
    1,850
    That's great, 12 months later and still going .... the good ol' 7812 does it get overly hot ... did you use a heatsink on it?
    and its good to see you are still around on the forum :)
    cheers
  18. vocal
    vocal
    35
    Apr 17, 2013
    One year... indeed, and still going :)
    I did not use heatsink.
    Im still around and still learning :)
  19. Capsicum
    Capsicum
    4
    Feb 28, 2014
    Hi Vocal, what brand machine was your board from? Mine is HyperExtension which may just be a rebrand of another manufacturer which doesn't help with locating spares unless the original manufacturer is known. Thanks in advance for any information.
  20. vocal
    vocal
    35
    Apr 17, 2013
    No idea what is the manufacturer. I wanted to replace mcb but could not find spares so with help in here I managed to repair it.
    Turn machine on, press start button and check the voltage to the motor. Then unplug the machine from the mains, disconnect motor and test voltage to the motor with motor disconnected. Also, can you hear a click (relay switching on) when when E1 appears on the display? Be VERY CAREFUL doing this. Post results.
