| On May 13, 6:33 am,
[email protected] wrote:
|> | Can a direct current with a potential-difference of
|> | 6,200,000,000,000,000,000 volts but an extremely weak maximum strength
|> | of only 1 electron per second move through air like the electric
|> | currents of lightning and stun guns can?
|> It certain can move through the air. But making it useful in some
|> controlled way is not likely to be possible. At that voltage it will
|> just do whatever it wants, which is most likely to bypass everything
|> you try to do to catch it and disappear out the other end.
| Okay.
|> | If so, is it possible to transmit this high-voltage, low-wattage [1
|> | watt if the math is worked out] DC electricity in a wireless manner
|> | through air molecules?
|> It likely will transmit. It likely will keep on going beyond where you
|> want to use the power. At this point it's nothing more than radiation.
| Then what is the maximum practical voltage [combined the minimum
| amperage] which can be used for any application? What is the minimum
| practical amperage?
| The application involves ridding the world of the need for wires and
| other metals [as much as practical] for the generation, amplification,
| attenuation, processing, recording, playback, transmission, and
| reception of DC electric currents without converted the DC current to
| any other form.
| Wireless DC electricity that remains purely-electric from point A to
| point B. Tesla's designs did not remain purely-electric as they
| involve transmission/reception of radio waves for power. Whereas, what
| I am thinking of remains purely-electric all the way along.
You're thinking of something akin to beta radiation. We try to avoid
that in large concentrations. They use this to kill anthrax in mail.
I worry it might be a cause of cancer.
Spend your time trying to figure ways to accomplish work using less power
and energy to do it. Maybe you can get your peecee to be efficient enough
to run on the ambient room light. People have built radios that can do
that, so why not a computer?
