TRANSISTORS
Discussion in 'Electronic Equipment' started by [email protected], Jan 8, 2007.
  1. Guest
    Hi,A VERY HAPPY NEW YEAR TO ONE AND ALL.I have some dougts regarding
    the transisters.
    how a common emitter transister is working.
    can any one explain me about transistor with circuit diagram.
  2. JeffM
    JeffM Guest
  3. That is a low impdaance output circuit.
    The emitter of the transistor is the output terminal. The input terminal
    is the base, while the collector is simply connected to the voltage
    supply. There is no voltage gain, but there is a good power gain in the
    form of the fact that the ac or signal current available from the
    emitter terminal is considerable.
    Angelo Campanella
