Transistors
Discussion in 'General Electronics Discussion' started by Kartik., Jun 1, 2012.
  1. Kartik.
    Kartik.
    7
    May 17, 2012
    "A base is wired to a voltage or current and turns the transistor on or off.
    Emitter and collectors leads connect to a positive or negative voltage source
    or ground. "
    Can someone put more light into this? I just have two ends of wire whose either ends are on a battery.
  2. Harald Kapp
    10,025
    2,138
    What do you want to do?
    Do you have a circuit you don't understand or just a transistor to test?
    Do you have any basic knowledge of electronics?
    Read up on transistor here: http://en.wikipedia.org/wiki/Transistor
    Harald
  3. Kartik.
    Kartik.
    7
    May 17, 2012
    I want to test a transistor and i'm a beginner in electronics
  4. Harald Kapp
    10,025
    2,138
    Sorry, but I think you are asking maybe a bit too much.
    May I suggest that you first undestand how a transistor operates before you test one? Google
    transistor basics
    The first hit for me was http://www.technologystudent.com/elec1/transis1.htm
    Good reading.
    Once you've mastered these basics, you will know how to test a transistor, too.
    Hint: A typical transistor has three leads so having a test instrument with only two measurement ports will not suffice to test the transistor completely.
    Harald
