H
Henry
Probably a dumb question, but found a site about transistors. They showed a
PNP as being between +V and a load, and a NPN as being between the load and
ground. Is this a conceptual convention or is this really neccessary? Can a
NPN be place between +V and ground. In dabbling with my old TTL chips (7400
series) I have been using NPN for everything. (Partly cause I bought a 15
pack at RS.) But in some cases I have had to invert an output to use an
NPN. Could I use a PNP in the same situation without inverting? I have been
using transistors for all my I/O. (mostly to a camera or a photo flash. Like
a flash delay circuit.) I understand the basic concepts of transistors being
amplifiers and switches (what I am doing) but dont know the practicle dos
and donts. Although my circuits work, I am worried that I might be using the
wrong transistors, or right ones in the wrong way.
Henry
Henry
