Transistors, Triacs, and Thyristors
Discussion in 'General Electronics Discussion' started by tedstruk, Oct 28, 2018.
  1. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
    What is the difference between an isolated and a non-isolated triac?
    [EDIT: irrelevant stuff removed]
  2. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
  3. Bluejets
    Bluejets
    4,977
    1,045
    Oct 5, 2014
    I'd say whether it is gated by the ac supply it is switching or some other "isolated" supply.
    Since you don't say just how you achieved this, then not much anyone can say either way.
    Don't you have Google...??
  4. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Most thyristors read as low ohms resistors when measured using those Chinese component testers.
    The isolated/nonisolated may refer to the packaging where some higher powered devices are totally plastic encapsulated with no terminal connected to the body of the device. Makes for easier mounting but not so good for power dissipation circuits.
  5. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
    found this great write-up on bidirectional thyristors....
    If I was not able to get a thyristor(of which I have ordered some from the orient)
    What kind of diodes and caps could I use in a replacement circuit?
    er how would I choose the diodes? by volt and Amp and then use a cap of the same Gate amps?
  6. Bluejets
    Bluejets
    4,977
    1,045
    Oct 5, 2014
    No idea what you are referring to..... o_O
  7. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Triac....
  8. Bluejets
    Bluejets
    4,977
    1,045
    Oct 5, 2014
  9. (*steve*)
    25,497
    2,839
    Let me rephrase your question in a way that everyone can understand.
    "I need some double ended chalk. What sort of cheese can I use to make that?"
    kellys_eye likes this.
