Transistors Query!
Discussion in 'General Electronics Discussion' started by junaid ahmad, Aug 14, 2016.
  1. junaid ahmad
    junaid ahmad
    Aug 14, 2016
    Hello everyone, Can anyone help me with BJT transistor.
    I want to generate Ic current of 0.34A with Vcc=9V, Vin=5V using BC547 but it looks like this transistor has Ic rating of 100mA. If i use BD139 or TIP122 transistor what is the Beta value for these two transistors.
  2. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    A transistor will not generate current, you need a dynamo or alternator:).
    The current gain of transistors is variable over a wide range. You should not use a circuit which depends on it.
    To drop 9V to 5V, use a 7805 regulator which can manage up to 1A and may need a heat sink. Do not forget the output capacitor.
  3. Rixen
    Rixen
    98
    23
    Feb 16, 2016
