Not sure what series this is
- NPN or PNP bipolar
or
- FETs
small-signal transistors in through-hole DIP package.
Where should I start looking?
The only one I know off off-hand is the MPQ2222, a quad array of
2N2222-type NPN transistors.
This part appears to be obsolete. You might find a few at surplus
dealers, or at the big $100-minimum-order IC consolidators. Blue Star
seems to have a couple of dozen in stock at $2 each (ouch!)
If you're thinking of going into production with parts like this, I
think you'll probably decide to redesign using more modern
surface-mount arrays. There seems to be little demand for DIP-type
arrays any more, and parts cost and availability are likely to become
an even worse problem in the future.
If you only need a handful, search around, or just make your own using
DIP headers and discretes.
