transistors, and capacitors
Status
Not open for further replies.
tedstruk
Jan 7, 2012
476
Jan 7, 2012
476
A transistor is basically a capacitor with an attitude. Rather than open after it heats up a little, It refuses to open unless power is supplied to the base. Same basic deal, different application conditions. I have a cheap Harbor freight multimeter, with NPN and PNP testing capabilities. It tells me the HFe of the transistor. Where in my basic electronics did I miss what HFe is?
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
The hFE is shown in all transistor datasheets to be the current gain. A transistor with an hFE of 100 when its collector current is 50mA will have a base current of only 50mA/100= 0.5mA when it is active and is not saturated.
The hFE varies with the collector current as shown in a graph in the datasheet, it drops at higher currents.
I have used a multimeter hFE test to match transistors.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Just curious, why is a transistor like a capacitor, am I missing something?
Adam
Ratch
Mar 10, 2013
1,099
Mar 10, 2013
1,099
A transistor is transconductance device (voltage controls current). It cannot be compared to a capacitor because a transistor is an active device, whereas a capacitor is not. The base current of a transistor is an indicator of the collector current (CC), but it does not control the CC. Vbe is what controls the CC in the active region of operation. The beta or Hfe is a measure of the unavoidable base waste current produced during device operation from carrier diffusion. A high Hfe transistor has less waste current for the same CC than a low Hfe transistor. If you drive the base with a current source, you have a current amplifying circuit which includes a transistor, not a lone transistor current amplifier.
Ratch
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
It is nothing like it.
I recommend you learn some basics about electronics.
Please don't make baseless statements like this. The is a small but real chance that someone might read what you say and think it has some basis in fact.
At least this post is not in response to someone else. I won't have to delete it.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
I wonder why all transistor datasheets do not mention transconductance but show current gain instead?
Ratch
Mar 10, 2013
1,099
Mar 10, 2013
1,099
That explanation was probably in the same section you skipped over, the one where they explained that transistors are absolutely NOT anything like capacitors.
Correct, caps store energy, transistors don't.
Ratch
Ratch
Mar 10, 2013
1,099
Mar 10, 2013
1,099
Although a transistor is a transconductance device, it it is not a linear parameter because of its diffusion operation. Driving the transistor with a current source shows a linear relationship with the collector current. This is because the high resistance of the current source swamps out the variation of the base-emitter resistance. Therefore, the base current vs. the collector current is of use. The base current is an indicator the the collector current.
Ratch
davenn
14,260
14,260
the OP's errors and Q's have been pointed out by several
as point out by others, this statement is just so wrong
thread closed
Status
