I'm learning by trying to repair a NAD cassette tape deck. When first powered on, the capstan motor (M701) runs for 1/2 second or so then shuts off. If I turn it on again less than 5 seconds later there is no response. Waiting at least 5 seconds, however, allows the motor to run for 1/2 second again. I don't believe the motor should run at all unless I press the PLAY button (Contact 4 in connector MP701).
With power on and after the 1/2 second run time, if I press PLAY, the motor runs for three seconds then dies. No amount of waiting will allow it to start again unless I de-power the whole unit for the five or more seconds mentioned above.
Can someone explain what is going on in the transistors Q275 and Q276? If the problem lies there, I have a hope of repairing it. If the problem is in the MECHANICAL CONTROL chip, then I might as well use the unit for experimentation because I can't find it online.
Many thanks for any help to this newbie.
