I have a non-functional 200W Wagan power inverter with 3 transistors in it. On their sides they say:
LT 028G
LVP
640
I'm only able to partially decode this. I don't know what "LT" is and I've searched a lot of datasheet databases. If it's a manufacturer's code it's not a very common one. If it's an abbreviation for something I'm too much of a noob to know what it is, and it isn't in any common lists of electronics abbreviations I've found.
028 could be a part type, for instance in comparison to a MJE15028G which looks similar. Maybe the parts have TO-220-3 cases but I'm not sure. G could mean it's lead-free.
640 probably means it was manufactured in the 40th week of 2006.
I don't know what LVP is. Could be a code for where it was assembled, but if so, I don't know where I'd find such codes. Maybe one can't, without knowing who's manufacturing it, and that's the original mystery. I've read that OEM runs of components can leave you SOL as far as their naming.
As I said I'm a noob. I've used my digital multimeter's diode test function to deduce that of the 6 possible electrical flows, only 1 works, and this is true for all 3 of the transistors. If these are bipolar transistors there should be 2 flows. That would possibly indicate that the transistors are all blown in the same direction. The other possibiliy is these aren't bipolar transistors, they're something appropriate for a power inverter, and I haven't gone up the learning curve enough yet. I'll be reading how to diagnose a MOSFET shortly. It sure would help if I knew what friggin' part I'm dealing with.
If these 3 transistors are bad, then my intent is to spend a few bucks to buy some replacements, and save myself the $35 a completely new unit would cost. In which case, the new parts need to meet or exceed the specs of the original equipment. That's why I wanted to find a spec sheet for the old parts. If that's not possible, then recommendations for a "robust" replacement for a 200W power inverter would be welcome. I've seen a lot of YouTube videos of a lot of power inverter repairs, and this kind of TO-220-3 looking transistor case seems quite common in them. However I haven't seen a video or found a web/forum/blog posting specifically about diagnosing and repairing transistors in this application.
LT 028G
LVP
640
