transistor in saturation mode
Discussion in 'Electronics Homework Help' started by srikar, Oct 2, 2015.
  1. srikar
    srikar
    Oct 2, 2015
    what I know is
    whatever may be the configuration (ce cb or cc)
    In active region
    Base emitter junction is forward biased and collector base junction is reverse biased
    In cutoff region
    Both the junctions are reverse biased
    In saturation region
    Both the junctions are forward biased
    lets now divert our attention towards the working of the transistor in the saturation region
    yesterday I was reading a book named electronic devices and circuits by david a bell .(page number 159 5th edition )
    in that he wrote that
    “if Vce went down to exactly zero volts , the collector base junction would become forward biased by 0.7v .in this case the collector base barrier voltage would be overcome and charge carriers from the emitter would be repelled from the collector base junction “and due to some things which were explained later in the book it doesnot happen so some collector current will flow so the voltage will Vce(sat)=0.2Vthis means the collector current should decrease as cb becomes forward biased
    let us now see CB configuration output characteristics of a npn transistor
    http://www.nptel.ac.in/courses/117107095/lecturers/lecture_11/images/fig7.jpg (pls see this link for characteristics)
    as we can see sir if we decrease the voltage Vcb below zero we know that collector base junction will start to become forward biased (if it reaches 0.7v then it will become CB junction will become forward biased ) . So as the cb junction is starting to become forward biased (i.e,. as Vcb<0 ) then collector current is starting to decrease .
    so as said above it is happening . So its fair.
    But my question is that it is not happening in the ce configuration
    when Vce reaches Vce(sat) maximum current is passing through the collector . How come this can happen ? How come transistor allows maximum current in the saturation region.
    the reason I am asking this is, in saturation region the collector base junction which is forward biased should repel all the charge carriers from the emitter . but still we all get maximum current flowing through the transistor when it is in saturation mode (applied that it is operating in the ce configuration )
    how come max current flow in ce but very least current flow in the cb configuration when the transistor is taken to their saturation region ?
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Let me start by saying you can not compare apples to oranges.
    The graphs are of the output characteristics(I -V curve)
    in C.E VCE vs. IC
    in C.B VCB vs IC
    The input is different as well iB vs iE
    For further understanding look here:
    I think you will like the content as well as the accent ;)
    part1
    part2
  3. wrighty
    wrighty
    10
    Aug 1, 2009
    Because the CB junction never becomes forward biased.
