Transistor Identification
Discussion in 'Troubleshooting and Repair' started by Andre Gopee, Sep 12, 2012.
  1. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Can anybody identify this transistor (D549). This is all the marking on the trans. I am trying to sort out my electronic components by identifying all the different parts and this one I am not getting any data sheet for it. Can anyone help.
    Andre
  2. shrtrnd
    shrtrnd
    3,781
    499
    Jan 15, 2010
    What type of package is it in?
    It could be a 2SD549.
    But I've seen some thyristors (in TO-220 type packages) with 'D' prefixes.
  3. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    It is in a TO127 Case style but I am still not picking up any data on this part number U gave me. I tried Mouser, NTE and Digchip. any suggestions?
  4. shrtrnd
    shrtrnd
    3,781
    499
    Jan 15, 2010
    All's I can do, is Gioogle it, which is what I suggest to you.
    I found references for an old D549 Thyristor, but no data sheet.
    A Toshiba 2SD549 Transistor and an
    AD549JH TO-99 8-Pin Op Amp
    I've never seen Analog Devices shorten their part number prefixes to just 'D', so that isn't it.
    Considering your package, I'd lean toward the Toshiba transistor.
    Couldn't you find a company logo on it anywhere? Maybe a date code if it looks old?
  5. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    It is defiantly not an 8 pin IC so I believe it is the Toshiba Transistor. The funny thing is that the supply shop has the part but they cannot say what it is either. There is no other marking on it except for T and a .6H. I have attach a picture of the component let me know if you can make it out.
    Regards,
    Andre
  6. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    It suppose to read definitely.
  7. alfa88
    alfa88
    331
    4
    Dec 1, 2010
  8. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Thanks Guys for the help. I have check the 2SD549 and it is definitely the part. I will keep a copy of the data sheet with that parts. Thanks again.
    Andre:cool:
  9. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Hey Guys, I need your help once more. I have attach a picture of what looks like an Optoisolator but I do not recognize the numbers which is 817CY. If any of you can assist me I would greatly appreciate it. Thanks.
    Andre
  10. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    I forgot to upload the picture. Here it is.
  11. (*steve*)
    25,448
    2,807
    This would be my guess.
  12. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Thanks Steve.
  13. shrtrnd
    shrtrnd
    3,781
    499
    Jan 15, 2010
    The company logo is for LiteOn.
    Your device is an LTV-817 Photocoupler (single channel, they make them in multi-channel DIPs too).
    They run about $3 each, U.S.
    Good luck
  14. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Thanks Shrtrnd
  15. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Valere Power Rectifier
    Hey Guys, I am repairing a Power Rectifier that is used in telecommunication services and I came across a part that I need the experts help to identify once again. I have attach a picture of the component for you to see.
    Regards,
    Andre
  16. grant1842
    grant1842
    11
    Oct 1, 2012
  17. grant1842
    grant1842
    11
    Oct 1, 2012
  18. (*steve*)
    25,448
    2,807
  19. Andre Gopee
    Andre Gopee
    35
    Sep 12, 2012
    Hi Guys its me again with another question. The board that I am repairing is soldered with lead solder and the normal 60w - 100w soldering is not melting the lead enough for the vacuume pump to remove it. any suggestion?
  20. grant1842
    grant1842
    11
    Oct 1, 2012
    Sometimes you need to add more solder to the joint then try to use a De- Solder gun with vacuum pump.
