Transistor ID
Discussion in 'General Electronics Discussion' started by Steve 1956, Aug 31, 2009.
  1. Steve 1956
    Steve 1956
    Aug 31, 2009
    I have a 1980 Eldorado with electronic climate control. I need to replace a transistor mounted to a copper heat sink, I cannot identify the device,
    the case is marked as follows:
    9379
    274
    HNP 7942
    Can anyone identify this?
    Thanks, Steve:confused:
  2. amdNRA
    amdNRA
    50
    Sep 3, 2009
    This is ONLY a guide :p...How do you know it is a transistor? But if it is, then see the type of case it has ie. TO-3, TO-220,etc. Try to identify the base; usually a smaller wire and see what kind of signal you have + turns on NPN -turns on PNP. Place current meter between collector and emittter (warning:several amps possible). Look in a data book for the correct transistor case, type and collector current. Look for generic transistors that meet your needs; nothing fancy here and don't worry about the Ft(frequency).
    Hope this helps, Gil. :)
