Transistor gate voltage
Discussion in 'General Electronics Discussion' started by sommech7498, Aug 13, 2017.
  1. sommech7498
    sommech7498
    4
    Aug 13, 2017
    Hey guys. I'm new to electronics here and need help figuring out a circuit I'm trying to make.
    I've attached an image below of the circuit I'm trying to make. Basically this is a tester for automotive purposes.it's a 12v circuit with a 100w rheostat/pot I'm using as a load. I will only be turning it on for a second or 2 max and really only plan on running 4-5 amps through it but want to be capable lf more if needed. I want to be able to turn on the transistor with a 9v and have the transistor and battery mounted on a pcb. I have 2 questions for this circuit. 1 is what kind of transistor should I be using. And 2 is how can I figure out what resistor to use for the transistor gate? Thanks for the help in advance.
  2. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
  3. Alec_t
    Alec_t
    2,910
    791
    Jul 7, 2015
    With a FET, as above, you wouldn't need a resistor in series with the gate, but you would need one (say 33k or so, not critical) between the gate and the source pins to ensure the FET turns off when the switch opens.
  4. AnalogKid
    AnalogKid
    2,425
    690
    Jun 10, 2015
    Your drawing has two wires going to what I think you mean to be the base of a bipolar transistor (not a FET). Also, there is no connection between the base circuit and the emitter, so it looks like nothing will happen.
    In your post, you don't say what it is you want the circuit to do. If you want the transistor to act as an on-off switch to put an adjustable load on the 12 V battery, you're not there yet. There are two circuit loops, one putting current into the base and one putting current into the collector. Both of these currents go through the emitter, which is why it has to somehow be common to both current loops.
    Rather than us give you a solution, why don't you do a little more research and take another swing?
    ak
    ak
  5. sommech7498
    sommech7498
    4
    Aug 13, 2017
    Sorry I drew it bad. Was in a hurry. The - on the 9 v would go to the emitter
  6. twister
    twister
    172
    7
    Feb 12, 2012
    When ever you have two voltage sources it is a good idea to separate them with a optical switch.
  7. AnalogKid
    AnalogKid
    2,425
    690
    Jun 10, 2015
    Not in this case. Having a separate voltage source for the transistor base ensures that the base current does not fluctuate if the 12 V source being tested sags under load.
    Also - IF you want the transistor to act as a switch rather than as a constant current source - the rheostat should be moved to the collector side of the transistor. This eliminates the possibility of the transistor not saturating because the resistance is too high, and burning up.
    ak
  8. sommech7498
    sommech7498
    4
    Aug 13, 2017
    Yea I didn't think about that for the rheostat. Thanks. would a mosfet be better for this situation? If I used a mosfet do I need to even have a resistor before the gate? Could I just give it the full 9 volts from the battery and hook the - of the battery up to the drain?
  9. Audioguru
    Audioguru
    3,042
    678
    Sep 24, 2016
    A 100W rheostat was used 100 years ago. Where will you find one today? Today we use a pulse-Width-modulation circuit controlled by a small inexpensive potentiometer or computer.
  10. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Can you explain what is the purpose of this circuit,is it to be a battery load?
  11. AnalogKid
    AnalogKid
    2,425
    690
    Jun 10, 2015
    No.
    Yes.
    No. Both battery negative terminals and the n-channel MOSFET *source* are tied together as the system ground. The drain goes to the rheostat, which goes to the +12. Add a 10K resistor from the FET gate to source so it turns off crisply when the +9 V is removed.
    ak
  12. Bluejets
    Bluejets
    4,419
    938
    Oct 5, 2014
    Why not just remove the transistor all together?
    Seems not to be operated by anything external.
    If an interface between two voltages, then a simple relay.
  13. sommech7498
    sommech7498
    4
    Aug 13, 2017
    Yes basically it's gonna load a circuit and let me check the battery and or wiring
    right now I have a regular switch doing this and I was gonna use a relay but I want to make this as small as possible. Later on down the road I'd like to add some other things to the circuit and a transistor would be ideal for me
  14. AnalogKid
    AnalogKid
    2,425
    690
    Jun 10, 2015
    The idea is to control a very large current with a much smaller current through a much smaller switch. A 100 A - 200 A contactor is far more expensive and less reliable than a suitably rated power transistor.
