transistor and diode blocking voltages
Discussion in 'Electronic Design' started by bumdegi, Oct 15, 2008.
  1. bumdegi
    bumdegi Guest
    Can someone please explain to me how transistors can block positive
    voltage whereas diodes block negative voltage.
    Cheers
  2. HardySpicer
    HardySpicer Guest
    Depends which way round they are connected and whether they are P or N
    type!
    Hardy
  3. Jasen Betts
    Jasen Betts Guest
    Diodes block reversed voltage due to the way in which the conduct
    electricty causing a break in the conductive path when they are
    reversed in relation to the voltage.
    http://en.wikipedia.org/wiki/Diode
    transistors can be used in combination with other electronic parts to
    regulate or block over voltage but how they work is more complicated.
    http://en.wikipedia.org/wiki/Linear_regulator
    http://en.wikipedia.org/wiki/Transistor
    MOSFETs (a type of transistor) can also be used like a diode to
    protect against backwards voltage.
    Further questions of this nature are bast asked in
    sci.electronics.basics
    Bye.
    Jasen
