Transistor Analysis
Discussion in 'Electronics Homework Help' started by Akshatha Venkatesh, Mar 27, 2017.
Thread Status:
Not open for further replies.
  1. Akshatha Venkatesh
    Akshatha Venkatesh
    145
    Jan 14, 2017
    Hi, can anyone help me with the circuit given below. what's the "voltage at this point" when the transistor is in saturation ? Is it Vce(sat) from the data sheet of the respective transistor ? and I also know the gain (hfe), so how do I calculate the collector current of the transistor when it is fully on (saturation) ?
    I'm trying to calculate the collector current , so that I can calculate the base current since I already know the gain.
    Thank You.
  2. Harald Kapp
    11,513
    2,651
    Assuming the transistor is in saturation, the voltae from collector to emitter is Vcesat. Since the emitter is at 0 V (common potential), this is also the "voltage at this point".
    Assuming further that the "ADC pin of MCU" has an infinite input resistance (At least much much higher than the resistances involved in the circuit shown), you can then calculate the currents through R0 and R1 from Kirchhoff'S and Ohm's laws.
    Akshatha Venkatesh likes this.
  3. Akshatha Venkatesh
    Akshatha Venkatesh
    145
    Jan 14, 2017
    So if the voltage is 0 V , how will the current flow there ?
  4. (*steve*)
    25,496
    2,837
    Why are you concerned that the voltage at the emitter is zero volts?
    Do you understand that the voltage at the negative end of the battery would also be labeled as 0V, and the emitter is at this potential because it is connected to it?
    The voltage at the collector is the voltage at the emitter plus Vce(sat). You'll have to look this up from the datasheet. This won't give you the exact base current because the relationship ib = ic / hfe only applies when Vce >> Vbe (and even then it is only approximate). In saturation Vbe > Vce. Ib will be significantly larger than the equation predicts and there is nothing much preventing it from increasing without bound.
    In addition, if you are actually using a different device (say a biased transistor) then the calculation simply doesn't hold. If you look at the datasheet there may be something else.
  5. Harald Kapp
    11,513
    2,651
    Battery-plus -> R0 -> transistor-C-E -> Battery-minus
    This holds for Vce > 0 V, too.
    A simple application of Kirchhoff's voltage law.
  6. Akshatha Venkatesh
    Akshatha Venkatesh
    145
    Jan 14, 2017
    What should I look for in the datasheet to find out the base current to fully turn on the transistor ?Please help
  7. Harald Kapp
    11,513
    2,651
    An NPN transistor is in saturation whenever Vbe < Vce (see here, 'regions of operation'). Therefore the threshold for entering saturation is Vbe=Vce. Any higher Vbe will only saturate the transistor more.
    The datasheet for this particular transistor only gives you Vcesat and VI(on). You'll have to use one of these values. Once you know the collector current in the on state you get at the required base current by using the DC current gain parameter hfe: Ib = Ic/hfe.
  8. (*steve*)
    25,496
    2,837
    I think you meant Vbe > Vce.
    You may need to have 3 to 10 times that base current for saturation.
    The datasheet may have enough information specified for its quoted Vce(sat) to allow you to compare the ib in this case with what you would calculate above. It's also worth noting that hfe varies between device and is not constant across large changes of ic.
    Do you have a link to the datasheet?
  9. (*steve*)
    25,496
    2,837
    Vce(sat) is given an 0.15V when Ic is 10mA. 0.5mA of base current (Ib) is required. The hfe is only listed as a minimum value (30). The rest of the datasheet might give more information, but clearly for saturation ib > Ic / hfe.
  10. Audioguru
    Audioguru
    3,309
    703
    Sep 24, 2016
    This must be a little BCxxx European transistor since its base current is 1/20th the collector current for saturation. Most little 2Nxxxx American transistors specify a base current that is 1/10th the collector current for saturation. hFE is not used for saturating a transistor. Power transistors (2N3055) sometimes use a base current that is 1/3rd the collector current and even with that much base current the saturation voltage is fairly high with a max of 3V.
  11. Akshatha Venkatesh
    Akshatha Venkatesh
    145
    Jan 14, 2017
    http://assets.nexperia.com/documents/data-sheet/PDTC114E_SER.pdf
  12. (*steve*)
    25,496
    2,837
    That's not just a transistor. Much of what has been started in this threat does not apply to that device.
    If you can change it to a normal transistor, or go back to the thread where we were discussing this circuit we may be able to help you with your homework.
    Also, please place your homework in the homework section.
  13. Audioguru
    Audioguru
    3,309
    703
    Sep 24, 2016
    That transistor has a 10k resistor in series with its base. It saturates not very well (0.3V) when its input voltage is 1.8V or 2.5V. If the input voltage is higher then it will saturate better.
  14. Harald Kapp
    11,513
    2,651
    Right, a type, sorry.
    The equation gives the minimum requirement. In practise it is common to use a higher base current as you say. However, note that if you use the minimum hfe from the datasheet, the typical value will be higher wich reduces the minimum base curent required. Therefore thebase current calculated from min. hfe will always be more than the typically required base current.
    Using Ib>=3*Ibmin is a useful rule of thumb.
    Right. The charm of this device is that it can be purely voltage controlled without the need for an additional base resistor as this is integrated.
    That having been said, I think it is not too useful for @Akshatha Venkatesh. A back of the envelope calculation using currents as requested could go like this:
    What is the max. collector current in the original circuit?
    Assume Vce=0V and no current flowing out of the MCU input (right side). Then Ic = Vdc0/R0. (note: a better value for Vcesat can be taken from the datasheet, figure 7.)
    Assume hfe = hfe(min) = 30 then Ib = Ic/hfe(min)=Vdc0/R0 * 1/hfe(min).
    You now have to make a further assumption about Vbe in saturation. Assume Vbe=0.7 V (this is an arbitrary but typical value. The datasheet does not state that value.)
    The current hrough R1 (internal) is I(R1) = Ib+I(R2). With above Vbe=0.7V: I(R2) = Vbe/R2.
    The required input voltage to drive this input current is Vin >= Vbe+I(R1)*R1.
    Do the math yourself.​
    Alternatively: from figure 8 of the datasheet take minimum input voltage to fully turn on the transistor at the collector current required.
  15. Akshatha Venkatesh
    Akshatha Venkatesh
    145
    Jan 14, 2017
    Which resistor is this R2 that you have mentioned above ?
    Thank You
    (mod edited for more specific quoting)
  16. (*steve*)
    25,496
    2,837
    They are the ones inside the biased transistor packages.
  17. Akshatha Venkatesh
    Akshatha Venkatesh
    145
    Jan 14, 2017
    R1 is referring to the biased transistor package too ? or the one in the above schematic which i have named as R0 and R1
  18. (*steve*)
    25,496
    2,837
  19. Harald Kapp
    11,513
    2,651
    Right.
    It is unfortunate that the resistor in the transistor package has the same name as the one in the circuit.
    I should have made that much clearer. I beg to excuse that lapse.
  20. Audioguru
    Audioguru
    3,309
    703
    Sep 24, 2016
    You need to allow for the awful +/- 30% (!) tolerance of the resistor values inside that transistor.
Thread Status:
