transisor characteristics
Discussion in 'Electronic Design' started by amila, May 19, 2006.
  1. amila
    amila Guest
    can any one send me grphs of transistor characteristics and explain the
    graphs using npn(pnp) junction.
  2. Ian Stirling
    Ian Stirling Guest
  3. Joerg
    Joerg Guest
  4. Ian Stirling
    Ian Stirling Guest
    It is really rather incredible.
    I'd love to say I predicted it, but my first response to the embryonic
    one was 'that'll never work'.
    The above entry is by no means perfect, I prefer the treatment in AoE,
    but there is nothing that I can see that is categorically incorrect, and
    of course, if I objected to it strongly enough, I could edit it.
  5. Robert Baer
    Robert Baer Guest
    Anybody could, but you should use google or other search engine to do
    that; many transistor makers have data sheets on most common bipolar
    transistors.
    Or a good search can be done via Mouser or DigiKey, using the part
    number(s) you have in mind.
  6. DaveM
    DaveM Guest
    I've never done anything like this, but you might try something like this:
    Record a couple seconds of noise, save it to a .wav file (Noise1.wav)
    Make a copy of the file (Noise2.wav)
    Using a wav file editor (such as Audacity), trim the beginning second of noise
    from Noise1.wav and save the file.
    Load Noise2.wav and trim the ending second from the wav file and save it.
    Now, load both files as separate tracks in stereo mode and then combine them,
    making a new mono track. Save the new mono noise file.
    Loop it and see how it sounds.
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Some days you're the dog, some days the hydrant.
