G
George Jefferson
When coupling capacitors are used to remove DC offsets between stages, does
there exist a dc component during startup? I notice that when I watch the dc
after a coupling cap that it starts out with a large dc component which goes
to zero. I assume this is because the cap is charging and eventually charges
to the dc component which blocks it resuling in a net 0 voltage after the
cap?
Suppose I have an amplifier stage and I couple it to that of a jfet. In this
case the gate is "floating". We could add a large resistance to ground
it(lets say it requires a very large resistance to prevent loading... 10M or
more). But will the gate initially have a large dc component which could
potentially ruin the jfet?
e.g., I have a very high ouput impedence(~1M-10M) transducer with a high
supply voltage(~1kV) and a relatively large DC offset(> 100V). I would like
to create an amplifier.
I've tried a bjt but it simply loads the signal too much and I can't get the
transistor out of cutoff without drawing too much current through the
resistors(trying to use 1/4W or 1/2W). When I do load the signal/heat the
bias resistors I can get some amplification(finally get out of cutoff) but
the signal is distorted because of loading and probably because it is too
close to cutoff.
Therefore I figured I could use a common source amp. Of course now I have to
worry about blowing the gate. The signal switch is within spec but the dc
offset would easily ruin it if it gets through the cap.
Anything I could do? It would be a relatively straightforward problem if the
output impedance and voltages weren't so high. I would like to use basic
techniques if possible rather than some exotic method.
If I could in some way buffer the signal then I can get away from the
loading issues which is really the only problem I'm having.
Obviously some floating gate method would work but the only thing I can
think of is a transformer and I'm not willing to go there.
cap?
close to cutoff.
