bigone5500
- Apr 9, 2014
- 712
- Joined
- Apr 9, 2014
- Messages
- 712
I have two Honeywell 198162P transformers that I want to use in parallel to achieve double the current capacity. The specs for these are as follows:
Primary: 120vac
Secondary: 24vac, 40vA
I have read that they need to be the same ratings to be able to do this. How close do the readings on each of the secondaries have to be in order for them to be used in a parallel configuration? Both have a secondary resistance of 0.8 ohms.
Primary: 120vac
