transformer
Discussion in 'General Electronics Discussion' started by seankee101, Apr 26, 2013.
  1. seankee101
    seankee101
    Apr 26, 2013
  2. BobK
    7,682
    1,688
    What 2 outputs are you looking for? Do they share a common ground, or must they be isolated from each other?
  3. davenn
    davenn Moderator
    13,838
    1,952
    hi there
    welcome to the forums :)
    You do understand that the transformer output is a 15V - 0V - 15V output
    it HAS 2 outputs ;) each one is 15VAC
    the 0V wire is your common wire
  4. BobK
    7,682
    1,688
    Unless he wants 2 isolated outputs. Which is what I assumed when he is talking about cutting the windings.
  5. quantumtangles
    quantumtangles
    152
    3
    Dec 19, 2012
    Is it a transformer which acts as a voltage divider? Which is to say, is the supply voltage 30 volts, (voltage into the device) but (instead of using resistors in parallel as in a conventional voltage divider), the ratio of windings results in a split power supply comprised of three terminals.
    One of the three terminals is +15v. The central terminal is zero volts and the third terminal is -15v?
    I think you may already have two outputs, using a common ground (the central zero volt terminal). Check out whether the 15v outputs are respectively +15v and -15v using a multimeter. If so (subject to the views of more august entities here present) it may be you have two outputs already.
  6. (*steve*)
    25,497
    2,838
    No, they're all AC.
  7. davenn
    davenn Moderator
    13,838
    1,952
    yup possibly :) but he hasnt come back to confirm that ....
    regardless, it would take little effort to split the loop that comes out onto the 0V terminal
    and easily produce 2 separate windings. No digging into the transformer required
  8. quantumtangles
    quantumtangles
    152
    3
    Dec 19, 2012
    Sorry Steve. I understand now.
  9. quantumtangles
    quantumtangles
    152
    3
    Dec 19, 2012
    The basic mistake I made was this.
    Transformers require alternating current to work. They cannot work with direct current. Doh.
