Transformer troubles
Discussion in 'Troubleshooting and Repair' started by Niranjan, Feb 2, 2010.
  1. Niranjan
    Niranjan
    3
    Feb 1, 2010
    totoidal transformer gets heated..replaced by new one but same problem...incoming supply through ups what may be the problem for overheating checked wiring also.
    plz suggest on same
  2. Niranjan
    Niranjan
    3
    Feb 1, 2010
  3. davenn
    davenn Moderator
    13,813
    1,945
    you havent said what the transformer is supplying power to or what sort of AC voltage
    is coming out of the transformer ( what should be coming out when circuit is working ok)
    disconnect the transformer from the circuit it supplies and check the circuit with a
    multimeter on resistance range. I would expect a few kOhms of resistance.
    And anything less than a few 100 Ohms would indicate a problem ie...
    a bridge rectifier has gone low resistance/short cct etc
    cheers
    VK2TDN
  4. Niranjan
    Niranjan
    3
    Feb 1, 2010
    Failure of Mosfet
    in my pcb there r mosfets . frequent failure of mosfets are observed what could be the reason the side of mosfets gets burned....plzz suggest
  5. vk5ajl
    vk5ajl
    8
    Feb 1, 2010
    It is not possible to say what is causing the fets to blow or anything very much without a schematic.
