Transformer Stacked winding arrangement
Discussion in 'Electronic Design' started by Martin Riddle, Aug 28, 2010.
  1. Can anyone recommend an older textbook that has details on different
    winding arrangements. Stacked, series, benefits etc....
    I'm looking for notations and trying to figure out what some of the
    arrangements are called.
    Cheers
  2. Tim Williams
    Tim Williams Guest
    For some reason I seem to recall that information is in RDH4 (Radiotron
    Designer's Handbook), which is out of copyright and available online. If
    I'm right, you'll find it in the output transformers section.
    Tim
  3. Thanks, I have a copy somewhere.....
    Cheers
  4. JosephKK
    JosephKK Guest
    Without looking at other answers, mostly it depends on what properties
    are needed. If high efficiency and high coupling are a target you
    tend to do multifilar windings; if independant tuning is desired
    (think [antique] IF cans) litz wire and other techniques are used; if
    high dielectrictric seperation (1.5 kV more) seperate bobbins are
    used; high MVA transformers other things are done.
