Jamie M
If the secondary of a push-pull ferrite transformer requires significant
HV clearance from the ferrite core will there still be enough coupling
for it to operate efficiently assuming the primary is wrapped right
onto the core? Also is it possible to use a simple ferrite rod as a
transformer at least somewhat efficiently? For making a secondary with
high clearance a ferrite rod is a lot easier than using a toroid or
core. I was thinking of a 1" diameter, 6" long ferrite rod, with a
single layer secondary 3" diameter and 6" long.
cheers,
Jamie
cheers,
Jamie
