Transformer replacement !
Discussion in 'General Electronics Discussion' started by Electric Al, Jan 7, 2020.
  1. Electric Al
    Electric Al
    84
    7
    Jan 16, 2014
    I have a guitar amp 230 volt . I would like to exchange the power transformer for a 120 volt . What is the best way to do this ?
  2. Tha fios agaibh
    Tha fios agaibh
    2,097
    707
    Aug 11, 2014
    You want the same secondary output voltage(s) and capacity (voltamp rating) as the original 230v.
    Post a picture of its specs.
  3. Minder
    Minder
    2,970
    626
    Apr 24, 2015
    Did you check to see that on the off chance the primary may be dual winding, 120/240 ?
    M.
  4. Electric Al
    Electric Al
    84
    7
    Jan 16, 2014
    I just wanted to verify ! Any suggestions where to purchase a replacement 120 volt transformer ?
  5. Tha fios agaibh
    Tha fios agaibh
    2,097
    707
    Aug 11, 2014
    ...so, Goldilocks installed the first transformer and said "this one is too big!" And then she installed a second transformer....
  6. Minder
    Minder
    2,970
    626
    Apr 24, 2015
    Antek makes and sells a nice line of Toroidal, you need to know the secondaries required and the approx Va size.
    M.
  7. bertus
    bertus Moderator
    752
    268
    Nov 8, 2019
    Hello,
    As others said, post some pictures of the primairy and secondairy side.
    If there are extra connections on the primairy side, it could be the transformer connections can be changed for 120 V.
    Bertus
  8. Electric Al
    Electric Al
    84
    7
    Jan 16, 2014
    I will post a pic as soon as I can !
