Transformer Primary open circuit
Fariha
Jun 7, 2012
8
Jun 7, 2012
8
Hello experts,
I have a sewing machine, Singer Futura CE 200.
There was a power surge and machine stopped working. I checked it out and found that the Transformer has open primary.
There is no ratings given on the transformer.
It has 2 primary wires and 6 secondary (2 blue 2 yellow 2 red).
The primary and secondary are connected to a PCB board
Please help me to know its ratings.
Regards
Fariha
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Is there anything at all written on the transformer?
Is there anything written on the PCB where the wires attach?
Maybe with a good sharp photo we could figure out reasonable voltages. Currents are another matter :(
If you had a second working machine it might be easier.
Harald Kapp
13,728
13,728
Are you sure it's the transformer?
I wouldn't be surprised to find a fuse (maybe not vey obviously placed) that has blown due to the surge.
Harald
khankll
Feb 6, 2011
110
Feb 6, 2011
110
transformer can be rewouned..
technicians wen remove old wire measure its guage and length and rewound same thing.. but the lamination sheets are opened.. and it doesnt works good..
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
I don't know much about sewing machines. Is there a simple power schematic glued
to the underside or inside case of the machine, that might show the voltages of the
circuits operating the machine? Did you try Googleing the make and model of the
machine in case you can find some information about the electrical side of it?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Nov 28, 2011
8,393
As Harald says, it could be a fuse blown, rather than the actual winding open circuit. Some transformers have various types of fuses built in. Remove the transformer and have a good close look at it. Perhaps you could take some close-up photos and upload them.
Fariha
Jun 7, 2012
8
Jun 7, 2012
8
Photos of the Transformer and PCB
There is nothing written on the PCB except CN1 and CN2 for connections,
As you can see in the photos.
On the Transformer ,on one side its says 85314 (which is singer's part no) and something TAM K 0520 which i dont understand.
On the core there is E76-LD/40 M-2 . Thats all i have.
Fariha
Jun 7, 2012
8
Jun 7, 2012
8
@shrtrnd,
I googled a lot and in one service manual I found the wiring diagram w/o any ratings :(
khankll
Feb 6, 2011
110
Feb 6, 2011
110
u can rewind it..
this type of transformer can be rewinded if carefull electrician is found :(
