S
Stanley Dornfeld
Hi Gang..
I want to power a rotating load. The load has many components. The input
voltage is 220AC. The eventual load will be 5, 12,and 20 volts DC for
computer type components. One rotation takes about two minutes. So! Here
is my idea.
For sake of discussion, the concept is:
An inside winding, which goes to the load and will rotate with the system,
might look like a cylindrical winding around a paper roll. The outside
winding will be fixed, and not rotate. It will also be cylindrical and fit
closely over the inside winding. An iron core may be used for efficiency.
The reason I'm looking at this is I want to get away from Slip Rings. The
transformer won't give off sparks and the interference associated with them.
Am I way off the cliff here, or does this concept make any sense?
Thank you for any suggestions.
Best regards,
Stan-
is my idea.
Best regards,
Stan-
