M
Mark
[Preamble]
Many years ago at school, transformers were simple things: you pop an AC on
one side (primary) and out pops a different AC (the secondary) on the other
side. I leant that this was a good way to step down (or up) voltages.
However, reading the FAQ and various pages I find that they're far from the
simple beasts that I once knew.
[/Preamble]
So here's the question:
I need a 9v 6vA AC output (input 240V UK mains). So I've purchased a
transformer that meets exactly that spec. What arrived is kind of this, but
not quite... At the top of the transfomer are two termoinals marked 230-240V
50/60Hz. So far so good. However, at the bottom, I have 4 terminals in a
horizintal line in 2 pairs. Each pair has 9v 3vA written above it. Now
before I set my house on fire wiring this up incorrectly (the input will be
fused ), can someone enlighten this newbie as to how I get the correct
output from this transformer? (Combine the two outputs? Send it back and ask
for the _correct_ transformer this time?)
Sorry for the noddy question!
TIA
Mark
[/Preamble]
TIA
Mark
