: On Thu, 17 Jun 2004 23:38:33 +1000, John Tserkezis
: >Dizzee wrote:
: >> Does anyone have a circuit diag. for a small tracking device.
: >> or point me in the direction of some publication or web
sites.
: >> I would like to make a short range (100-200m) for... and I
know it's a bit
: >> sad... my cat.
: > Something like a crystal oscillator with buffer (just supply
5v). Looks like
: >a smallish rectangular can with four pins (only three used, 5v
in, gnd, and TTL
: >output).
: > Output goes to a loose wire.
: > Use a scanner tuned to listen to the carrier, and a
directional antenna will
: >help with the direction.
: > A dipole will have two "blind" spots, a bit of triangulation
will tell you
: >which of the two blind spots is the real direction.
: RDF (Radio Direction Finding or "Fox Hunting") is the right
approach,
: however, in what you describe the battery life for a battery a
cat can
: carry would be under a day, believe I know from first hand
experience
, that is, transmitting at the legal max power for
non-licensed
: public frequencies.
Actually a small pulse at 400 to 500 mS intervals is enough to
track. A 100 mW signal will handle the range, and with a 50 mS
pulse the average power is less than 10mW. Most small batteries
like a AAA will last quite a while at that poser level. Maybe
even several days.
Three AAA cells should do it, and at 560mA and a load of 15mW
total, the batter8ies will last at least 48 hours. Maybe a little
more.
The frequency should be picked with an eye toward low
interference and easy access to a receiver. If you use a small
short-wave receiver 10 meters is pretty quiet now. (sun spot cycle
near low) so it would be pretty useful and an antenna can be
pretty short, just wire in the harness the cat wears. Tuning the
antenna with a bit of inductance will improve the range, you'll
have to experiment.
Good luck, sounds like a fun project!
: Everything is worse case, from lack of an antenna ground plane,
to the
: antenna positioning, the power you can transmit, the practical
weight
: a cat can deal with, the frequencies you can use, to the places
cats
: hang out, like under parked cars, behind bushes, buildings,
under
: houses even.
: Directional antenna (yagi's), doppler, and TDOA (Time Delay on
: Arrival) are the core RDF approaches, all have significant
drawbacks
: for this application, but TDOA has worked out to be the most
practical
: for me. Using the "body-block" a lot of times you can resolve
the
: direction 0/180 without the triangulation dance, if you have a
signal
: strength reading, which is also good for distinguishing
reflections
: from the real source signal.
