TPS63000
Discussion in 'Electronic Design' started by AJ, Feb 27, 2007.
  1. AJ
    AJ Guest
    I have been prototyping a TI TPS63000 Buck-Boost converter and have set up a
    circuit as per the datasheet but I am finding that the quiescent current
    with no load is about 2.5mA with a 4V input and a 3.6V output where the
    datasheet states that it should be < 50uA. Has anyone else had any
    experience with these particular devices?
    Here is a link to the datasheet for anyone interested...
    http://focus.ti.com/lit/ds/symlink/tps63000.pdf
    Best regards,
    AJ
  2. mpm
    mpm Guest
    Sorry, not familiar with that one.
    You might look at the Enable and make sure it's driven completely to
    the rail.
    Buck/Boost regulators sometimes pull extra juice when not fully
    enabled (or disabled).
    Good luck.
    -mpm
  3. AJ
    AJ Guest
    Thanks anyway but I have it all sorted now. I ended up bringing out the old
    etching tank and making a PCB so I could easily play with the EN and PS/SYNC
    pins. It turns out that the PS/SYNC pin needs to be low to achieve the
    advertised <50uA quiescent current.
    Best regards
    AJ
Similar Threads
Loading...
