Touchscreen 4 or 5 wire -- how to determine
Discussion in 'Electronic Design' started by [email protected], Oct 11, 2006.
  1. Guest
    There are 4 wires coming from my touch screen:
    1 - right of panel (X2)
    2 - left of panel (X1)
    3 - bottom of panel (Y2)
    4 - top of panel (Y1)
    I am not sure if 4 or 5 wires is referring to the numbers of output
    pins (as listed above) or the number of wires internal to the resistive
    touch screen. If you take a look at page 1 of the following link there
    is a four-wire and a five-wire diagram both having a 4 wire output.
    http://focus.ti.com/lit/an/sbaa036/sbaa036.pdf
    If both cases (4-wire and 5-wire) have a 4 wire output how can I
    determine how the touch screen was designed? The datasheet and support
    for the screen is horrible!
    Thanks for the info!
    -Henk
