Touching halogen bulbs
Discussion in 'Lighting' started by Andy, Apr 27, 2006.
  1. Andy
    Andy Guest
    Is it too late to clean a quartz bulb if I have touched it during
    installation?
    I will have already deposited skin oils and grease.
  2. David Lee
    David Lee Guest
    Andy wrote...
    You can clean the envelope using alcohol - surgical spirit or iso-propyl
    alcohol, as available. Then don't touch it again!
    David
  3. No. Just clean the bulb surface.
    Vic Roberts
    http://www.RobertsResearchInc.com
    To reply via e-mail:
    replace xxx with vdr in the Reply to: address
    or use e-mail address listed at the Web site.
    This information is provided for educational purposes only.
    It may not be used in any publication or posted on any Web
    site without written permission.
  4. I'm thinking at most a slightly shortened life span of the lamp.
  5. TKM
    TKM Guest
    Assuming the lamp is a general lighting lamp -- no big deal. Clean it
    (alcohol or window cleaner will do), wipe it dry with a tissue or clean
    cloth and turn it on.
    Or, just forget it unless there is some sophistocated optical system
    involved. The worst that can happen is that the surface of the quartz will
    diffuse slightly. Lamp life will not be affected.
    Terry McGowan
  6. David Lee
    David Lee Guest
    wrote...
    You would probably need to apply the grease with a butter knife! In my
    experience contamination tends to lead to de-vitrification of the quartz
    envelope and early failure but I've never had one burst. I always believed
    that it was the salts from your fingerprints that did the real damage -
    diffusing into the silica - but of course you need to dissolve the finger
    grease with alcohol before you can wipe off all the salts.
    David
  7. TKM
    TKM Guest
    The early failure and/or rupture of halogen lamps contaminated by finger
    prints or grease are widely-held notions; but in several decades of product
    service experience with a major lamp manufacturer and the inventors of the
    halogen lamp, I've never seen any evidence of such a problem with general
    service halogen lamps. Sure, dirt can cause some fogging (devitrification)
    of the quartz surface; but that's a long ways from bulb softening and
    failure.
    I'd be interested in hearing from anyone who (really) has had or seen such
    problems -- again emphasizing for general service lighting lamps, not
    stage/studio, reprographic or other special purpose halogen lamps that are
    designed closer to the limits of the materials.
    Terry McGowan
  8. TKM
    TKM Guest
    Stage/studio lamps are certainly more likely to have problems such as you
    describe. For one thing, the filaments are operated at higher
    temperatures -- 3200K vs. 3000K, for example.
    It's normal for the quartz envelope to glow after switch off; but not to
    bulge. That says the temperature of the quartz is at the softening point.
    Not good.
    I wonder if the reflector was refocusing the energy back onto the lamp in
    that particular case. Sometimes when a spherical reflector section is used,
    that happens.
    Terry McGowan
  9. Zak
    Zak Guest
    I've had one fail after a 1 meter fall while on (220 volt tube).
    It kept working and I placed it back. I thought: hmm, these are fairly
    string. About 30 seconds later it went, I believe taking the house fuse
    with it. It had spewn out its filament over quite a distance.
    Please keep the fittings grounded/earthed.
    Thomas
