Touch lamp stays on constantly
Discussion in 'Electronic Repair' started by Doc, Apr 4, 2007.
  1. Doc
    Doc Guest
    The bulb burned out on a touch lamp I got at Wal Mart a while back and
    when I replaced the bulb, I find it stays on all the time. Now I don't
    use it since it doesn't have any other on/off.
    What's the likely cause of this and is it something that's readily
    repairable?
    Thanks.
  2. Meat Plow
    Meat Plow Guest
    Not repairable, toss it or wire an inline switch.
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  3. Eeyore
    Eeyore Guest
    Probably a triac went short circuit.
    Easily fixable.
    Graham
  4. Walmart or Home Depot have replacement touch lamp modules for about...
    it may have been $10. You just have to find the right rack.
  5. James Sweet
    James Sweet Guest
    This is common, the bulb arcs internally when it blows and pops the
    triac in the dimmer module. If it's not potted in solid epoxy it's easy
    to fix and I've done several. You can get a triac at Radio Shack that
    will work, it doesn't have to be an exact replacement. In the dimmers
    I've fixed so far that was the only problem.
