total newbie needs help
Discussion in 'Electronic Design' started by s, Aug 10, 2005.
  1. s
    s Guest
    Hi all,
    Got a bit of a problem that am hoping you can help me with...
    I need a momentary switch, easy enough I hear you say, but due to the
    nature I need it to be timed...
    Quick background, it's for the electronic gearchange on motorbikes. An
    excellent firm produces an electronic gearchange for disabled bikers.
    Gearchange is done by hitting one of 2 switches.
    The problem is if the button is held for longer than 500ms then the
    changer just keeps going on and changing gears...
    What am hoping to achieve is a circuit that can be put in-line, that
    will only allow a single "pulse" for less than 500ms..
    Hope you follow that and can help me out a bit..
    TIA
    sparks
  2. Bob Stephens
    Bob Stephens Guest
    Google for 'One shot'
  3. sparks
    sparks Guest
    ty... perfect
  4. Pooh Bear
    Pooh Bear Guest
    LM555 monostable mode.
    Graham
  5. Naveed
    Naveed Guest
    If you don't know what your doing then you might want to think twice about
    your project.
    If your going to use this to move up gear or down gear using this device and
    it produces a spike or some kind of noise, it could causes the gears to
    shift down when your travelling at high speed, it might become abit
    dangerous.
    Naveed
