Toshiba TV model 27A44, Regulated B+ Info
Discussion in 'General Electronics' started by Brad, Dec 3, 2008.
  1. Brad
    Brad Guest
    I have a Toshiba TV (27" pic) model 27A44 (mfg. 05/04) in my TV service
    shop (no SM). Customer told me the TV "sparks" once in awhile, then turns
    off. It didn't do it in the shop yet, but checking the HV, it was 30KV
    (higher than normal). I checked the regulated B+ and it measured +122V!
    Unfortunately, there is no marking on PCB that indicates what this voltage
    should be.
    I removed and tested the timing capacitors in the horizontal output
    circuit. Sometimes an open capacitor will cause the HV to go higher
    than normal. They tested just fine.
    130V is very common in my experience, but can someone tell me what the
    regulated B+ should be in this model TV?
    Thanks in advance, Brad
    Before you type your password, credit card number, etc.,
    be sure there is no active keystroke logger (spyware) in your PC.
  2. neon
    neon
    1,325
    Oct 21, 2006
    no matter what the b+ is the HV comes from a 1-2v source. and the b+ whether right or wrong shoul'd boost the HV to 30kv. and to me 130v is not much for a 27" put a load and see if it regulate if it does then it is correct and look into your real problem hi HV
