Toshiba TV audio distortion
Discussion in 'Electronic Repair' started by Douglas C. Niedermeyer, Nov 9, 2004.
  1. Got a 7 year old Toshiba TP50F90 50" rear projection TV with average 6-7
    hours per day use that's started distorting sound on most channels when set
    to stereo. It sounds OK when set to mono. And the sound is OK playing
    pre-recorded DVSs or VHS tapes. So my layman's guess is the problem is in
    the TV's tuner's stereo circuitry. Cable company came out and checked the
    cable and it's OK.
    Describing these symptoms to local (Atlanta) TV repair guys brings "blind"
    estimates in the $500 range to fix.
    Anything I can tackle myself? Worth fixing? Time for a new TV?
    Doug
  2. NSM
    NSM Guest
    set
    | cable and it's OK.
    Keep shopping for a good tech. Ask friends and neighbours. Avoid the low
    ball guys however, who will run the bill up after they start.
    N
  3. Art
    Art Guest
    Possible the audio processor within the mts assembly. If I remember it looks
    like another tuner assembly.
  4. Thanks for the responses. Anyone else have any thoughts on this?
    Doug
  5. john
    john Guest
    SBX module inside the Audio Module.
    kip
  6. dx375
    dx375 Guest
    Doug,
    Toshiba replaced part of my audio circuit for the same set when it was
    under warranty.
    The tech did note that there was a design flaw that Toshiba was aware of
    and that it had to do with some of the wiring being to close to the (a)
    highvoltage part of the set.
    They replaced the part(s) and re-routed the affected wiring.
    Cheers Dave
  7. dx375
    dx375 Guest
    Doug,
    under warranty.
    Cheers Dave
