Toshiba SD-V393SU2 DVD/VHS Combo
Discussion in 'Electronic Repair' started by dogadog, May 5, 2007.
  1. dogadog
    dogadog Guest
    In a nutshell: Unit itself operates fine as a tuner, the VCR works quite
    well, but any attempt to play ANY sort of disc in the DVD player causes the
    unit to shut off. The power button won't turn it back on either. The only
    way to get it started again is to unplug the unit for several minutes, and
    once the display comes on, open the DVD tray as fast a possible to get the
    disc out before the machine tries to read it and shuts off again.
    It's no longer under warranty, and is otherwise a nice machine. Worth
    repairing, I believe. Anyone out there have any idea what I should look at
    first?
    Jon
    Kentucky
