Toshiba rear projection T.V.
Discussion in 'Electronic Repair' started by Dani, Aug 31, 2006.
  1. Dani
    Dani Guest
    Got a call on this one, can't find anything online. Plug in, turns on,
    perfect pix, & sound, after about a minute pix goes black, sound stays,
    have to unplug, & start over. Convergence is fine. Ideas? Dani.
  2. Tech Data
    Tech Data Guest
    Dani, if you'll post a model number, I'll see if I can dig something up
    on this. Also, have you looked at it yet or, are you going by the
    customer description? Lemme know.
    www.techdata-kicksass.net
  3. Dani
    Dani Guest
    Sorry. Model # TP61H60, just 61H60, chassis # TAC9865. Dani.
  4. Tech Data
    Tech Data Guest
    I was going to suggest the vertical IC but, that normally causes
    instant shutdown. Only tip I could find that might help is as follows:
    Shutdown, not vertical or convergence. Q370, C370, and C371 all leaky.
    2SA933S, 100uf50v, 10uf35v. Near tuner modules.
    Good luck.
