Toshiba DLP problem.
Discussion in 'Electronic Repair' started by Dani, Mar 17, 2007.
  1. Dani
    Dani Guest
    Toshiba 44NM84 DLP has a black bar down the right side of the screen,
    where there is no video, as if the "eye" of the optics in the light
    engine is out of alignment I talked to Toshiba, Canada,
    & I can replace the light engine with a rebuilt one, or apparently
    repair the light engine, by replacing a part inside. Has anyone done
    this before? Because most manufacturers won't let you
    fix a light engine, & also charges a "dud" fee, but now you can buy
    rebuilt ones! Have the rebuilt
    light engines worked out ok? It's extended warranty, & I would rather
    get the whole rebuilt part.
    Thanks, Dani. Here's a pix of the fault.
    http://www.hometheaterspot.com/attach//808663-Line1.jpg
  2. Bob Loblaw
    Bob Loblaw Guest
    It appears as though the light tunnel has come "unglued". I have replaced
    the light tunnel ass'y, repaired it and replaced the entire light engine in
    different situations.
    Rebuilt light engines seem to work fine for the most part.
