Toshiba CX2778 Won't turn on
Discussion in 'Electronic Repair' started by 1Mannong, Aug 23, 2005.
  1. 1Mannong
    1Mannong Guest
    I can't get my tv to turn on. I hear a "click" from the relay whe
    plugging the set in, but the power won't "stay" I have read that th
    capacitor c840 is to blame for this, but is that true? what do i do?
    help please...
    Ji
  2. sofie
    sofie Guest
    1Mannong:
    How can anyone know if C840 is to blame for the malfunction.... there are
    many faults that could cause your television to "not turn on."
    The television will have to be opened up and parts tested with test
    equipment to determine the actual fault. At the very least you should TAKE
    it to a service shop for a repair cost estimate so you can make an
    INTELLIGENT repair decision with facts instead of Internet or Telephone wild
    guesses.
    My car won't start..... is it the battery?, the starter motor?, relay or
    solenoid?, bad ignition?, bad computer module?, bad fuel injectors?, .....or
    maybe a bad mechanical part in the engine? ! Obviously, tests need to be
    done by and experienced and knowledgeable tech to determine the problem and
    fix it.
  3. Guest
    Open the tv up and esr check any suspect capacitors.
    If that yields no firm answer, troubleshoot the tv.
