Toshiba CX 35E60 took a hit, now no pic or sound....
Discussion in 'Electronic Repair' started by CTB, Jun 27, 2004.
  1. CTB
    CTB Guest
    I don't think it took a direct hit, because everything inside looks
    fine. But I do think that a power surge during a storm took it out.
    Now when I hit the power button, the light comes on, but nothing else
    happens. No pic/no sound. I've been advised to replace the power
    supply, but I'm a novice, so I'm not sure what the actual part
    name/number would be. But I figured it is worth a shot in any case.
    Does anyone know what the part number would be for a power supply on
    this model? Also, I found a place to order the service manual for
    this model - is that the same as the schematics?
    Any help would be appreciated!
  2. Art
    Art Guest
    Best to have a professional have a look at the set and give you an estimate,
    not a job for an amatuer.
  3. David
    David Guest
    Can you troubleshoot and repair the tv set?
    The power supply is not a replaceable part. Everything is on one main board
    and it is designed to be repaired to the component level by a trained
    technician.
    Since the light comes on, it clearly indicates that at least most of the
    power supply system is working, as is the system control. More likely some
    run supply or deflection has the problem.
    Time to take the set into someone qualified to look at it.
    David
