Toshiba color TV audio problem
Discussion in 'Electronic Repair' started by Patrick Wetmore, Nov 25, 2005.
  1. Hello,
    I have a Toshiba CF2668B color television. The audio died on it - does
    anybody know of any common faults in this model TV that may cause such a
    problem, so I can start figuring out what went bad ?
    - pat
  2. Chuck
    Chuck Guest
    If this is the one with the if and video processor sealed in a metal
    box, the sbx1637 module in this can needs to be replaced. Chuck
  3. I thought only Sony used that module. Did Toshiba use it too?
  4. kip
    kip Guest
    Goldstar / Sony / Toshiba use them along with others...
    kip
  5. kip
    kip Guest
    Also Samsung.
  6. Thanks! There is some stuff under a metal box, as I recall from the time I
    worked on some deflection problems.
    Where can I order the sbx1637 from ? Is it available from www.mouser.com (a
    search there didn't reveal anything), or is this a proprietary part ?
    Thanks again,
    - pat
  7. kip
    kip Guest
    MCM Newark has them.
    kip
