Toshiba 50V71 Chasis TAC 9958 Convergence Issues
Discussion in 'Electronic Repair' started by Chance, Oct 9, 2007.
  1. Chance
    Chance Guest
    Need help troubleshooting convergence issues on this set. Have
    replaced both STK 392-110. Replacing the stk's seem to have not had
    any effect. I've checked all of the resistors near them and haven't
    found any open. I don't see any pico fuses to check. Is there any
    way I can rule out the digital convergence board? I could probably
    post a pic if this would help. Any ideas would be appreciated.
    Thanks in advance.
    Regards,
    Chance
  2. b
    b Guest
    do you say 'issues' when you mean 'problems '? ;-)
    have you the schematic=? if not , try eserviceinfo.com
    -B
  3. AJ
    AJ Guest
    Check the +/- voltages to the STK Devices, either one missing indicates
    either an open fuse device and/or power supply problem. A bit more deligence
    checking those particular circuits may resolve your problems.
