Toshiba 50H82 contiuning lines noise in picture problem.
Discussion in 'Electronic Repair' started by Jason D., Mar 22, 2006.
  1. Jason D.
    Jason D. Guest
    Already checked and replaced capacitors in hyper module (big tin box,
    including 11 10uF caps). Replaced weak caps in power & deflection
    board with no luck.
    Noise horizontal lines across picture are sharp and spacing are
    non-linear vertically and changes in positions all the time, sometimes
    disappears when bright images appears, reappears when image is dimmer.
    Eventually this noise disappears after several minutes.
    Help?
    Cheers, Wizard
