Toshiba 36" TV
Discussion in 'Electronic Repair' started by TAFT HAYNES, Jun 17, 2004.
  1. TAFT HAYNES
    TAFT HAYNES Guest
    Hello Group: This unit had water spilled on it, after cleaning corrosion
    around power switch, and resoldering that area. The unit would power up
    again. However it looks as if it needs to be deguassed. Rainbows of color
    on both sides. Deguassing coil won't remove.
    Any suggestions would be appreciated
  2. Art
    Art Guest
    Try to manually degauss the set, if you have access to a degaussing coil or
    have a service shop come out and do it. Has the set been subjected to any
    type of physical force, such as being rolled over or dropped??
