Toshiba 32A10 TV Sound problem
Discussion in 'Electronic Repair' started by Chillspine, Oct 7, 2006.
  1. Chillspine
    Chillspine Guest
    I have a Toshiba 32A10 (32" TV) that generates overwhelming white
    noise (sound) from all CATV stations, from both the set's own
    speakers, and from externally-amplified ones. The CATV signal is
    fine; another TV can use that same cable with no noise.
    The picture is fine.
    The actual sound from the CATV input is barely audible, but it's very
    faint, and is swamped by the noise.
    Using input from an external DVD player, the sound is perfectly fine.
    Which component is the likely culprit? Since external speakers (which
    receive unamplified signal) also receive the noise, could it be the
    tuner module?
    Thanks for your time!
    Chillspine
    P.S. I fully understand the risks of working on TV equipment; I hereby
    indemnify and hold blameless any parties kind enough to part with
    their $0.02 ;)
  2. Guest
    Try turning off SAP or other audio options in the user menu.
  3. Meat Plow
    Meat Plow Guest
    Tuner.
